HTTPS configuration for REST SERVER
  • September 26, 2024
  • 2 replies
  • 793 views
hi, am trying to connect to my webserver using IIOT Gateway pulgins Configured as REST SERVER,
Since it was tested using HTTP during testing , it was working fine , While for Production we have to do it in HTTPS.I Am a not able configure it , Support needed.
Thingworx Kepware SERVER EX V6.16.217.0
As iam trying to upload SSL certificate, its showing format error.
''Failed to import the Certificate. the format is in valid''
There are many things that could be incorrect with the certificate – some common ones are:
Please go through the article attached for the resolution.
https://www.ptc.com/en/support/article/CS412176
Mohit
Catalina
Community Moderator
October 1, 2024
Hi @VS_12009440,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Catalina | PTC Community Moderator
