Cylinder under external load
- January 12, 2011
- 42 replies
- 24160 views
I am currently having trouble designing a reel winder in work, picture included below to help with the explanation.
If you can imagine the wire coming off the bottom of the barrel and attached to a pipeline thus, putting the wire in tension. The tension in the wire creates a compressive stress in the barrel (hoop stress).
From here I have used to Hoop stress (also known as the circumferential stress) to find the external pressure using Lame’s equation, which is shown in the attached *.pdf.
From the solve block the external pressure seems acceptable, but the resultant tangential stress seems excessive.
Can anyone confirm if my Maths or logic is correct? I have been told that this could be calculated using the principle stress theory or a method out of Roarks, any ideas?
Mike
