MathCAD Units Help
I am using MathCAD Prime 2.0 for design calculations for a building I am engineering. I am fairly new to MathCAD, only learning a little about it in college. However, I am running into a units issue when calculating pounds per linear foot (lb/ft) to just pounds (a point load). I am taking 480 PLF * 4 ft, the feet should cancel out and you are left with just pounds. MathCAD is spitting out a lb*f, like the units for a moment. When I go to change the units to just pounds then it changes my units to (ft/s^2)*lb? Please explain to me what is going wrong here. See below for a screen shot:math+cad+question.jpg
Please note that the answer is correct, 1920 pounds is the right answer. Just the wrong units.
Thank you in advance,
Jon Recknagel | Structural Designer
I just answered my own question. A "lbf"= a pound force. It seems like they could have just left it at "lb" we are all aware that pounds is a force. Just my opinon I guess. Thanks anyway.
ptc-49926781-VisitorAuthorAnswer
The pound is a unit of mass, not force.
I would disagree....Pounds (lb) is not a mass. Pounds is a force. F=mg, due to gravity.
The "lbf", pounds force is there to differentiate between pounds mass, which is just "lb". Something which matters greatly when doing dynamics, rather than statics.
You may want to check how the different units for Force per Length are defined in Mathcad
Maybe this thread is helpful http://communities.ptc.com/message/30166#30166
23-Emerald I
Careful!
You've run afoul of Mathcad's rule to use only the units required.  The definitions are valid if you proscribe the units
