Numerical issues with Symbolic Derivative Operators
In order to apply the classical Van der Walls Critical Isotherm Conditions to a  Carnahan-Staling based EOS, I make use of the derivative operators within a solve block.  I found discrepancy between the derivative evaluated by using the symbolic derivative and the expanded derivative ( calculated symbolically ). Furthermore the solve block does not converge with the symbolic derivatives, while it does ( "better" ) with the expanded derivative.
Please post a worksheet showing the problem. It's not possible to give you any kind of answer without a worksheet.
mnori1-VisitorAuthor
In the attached worksheet, after the EOS contributions definitions, you could find the isotherm critical conditions non linear system: 1) Non linear system for only dispersion forces EOS using the symbolic derivative; 2) Non linear system including the EOS association contribution ( Wertheim's theory derived ) by using the explicit derivative 3) Non linear system including the EOS association contribution by using the symbolic derivative.
In the second attachment , you could find for instance the procedure for fitting the EOS parameters ( here the explicit derivatives calculated  even written a bit differently) for the pure compounds.
in the third attachment, similar procedure for not associating compounds.
23-Emerald V
Good Morning, Massimiliano
I've just had a look at Benzene.xmcd and there is an undefined variable error where it tries to access an element of the variable Benzene.  Where is Benzene defined - I can't see it in the worksheet?
Stuart
