Odesolver
- May 29, 2013
- 5 replies
- 2821 views
This is my first post. I have been trying to get the ODESOLVER to work in the PRIME 2.0. It took me awhile to get even the help examples to work. I think I figured out that you have to use the ctrl+= when you set the constraints like in MATHCAD 15, but the help files do not tell you that. I figured that out by watching some u-tube videos.
In any case, I am trying to solve a simple ODE to plot the displacement of a particle given a velocity function. The application is applying ocean wave theory.
Any help would be appreciated, I have spent too much time trying to figure out this simple problem so I can then add other velocity compents to get my final answer.
My file is attached.
Thanks.
John T.
