On 5/5/2009 8:23:13 AM, YuK wrote:
>Hi All.
>http://en.wikipedia.org/wiki/R
>unge-Kutta
>We know Runge-Kutta metod 4-th
>Order Approximation has 4-th
>Order Approximation. How to
>view this by Mathkad?
>Thanks.
>YuK
_____________________________
Not sure what you are looking for, YuK
Here is also Fehlberg 45.
jmG
Is 4th global, but that's only because is 5th local. You can see that with the 'symbolic not found' for a serie of order 5 in your setup.
To evaluate the local error, you starting acotating the value e = |yn+1-yn|. To do that, assume at first that yn have not error! (which is absolutely false).
Regards. Alvaro.
