This Expression Redefines a Previously Defined Variable
I am working in MathCad 11. I define a variable "x:=10". Further down the worksheet, I wish to change this variable to "x:=20" for example. When I do so, MathCad underlines the variable with a green zigzag line which tell me that "This Expression Redefines a Previously Defined Variable." The subsequent calculation use the later value, but the page has these annoying green zigzag lines.
Is there a way to eliminate these zigzag lines?
Thanks.
