Creo vs. Solidworks vs. Inventor
I feel like I need to vent a little, so I was hoping to get a discussion started as to why Creo has any advantage over the other popular 3D CAD modeling systems. I want to like this product, I really do, but right now, I feel like I am being forced to learn a dying system. Creo will not survive if they do not change the way things are done.
I am new to Creo (6 weeks), but I have used Inventor for the past 3 years. In my opinion, there is no comparison between the two. Inventor is significantly better than Creo in pretty much every single way I have been using the system.
Component Modeling:
Creo is completely unintuitive. For the novice trying to obtain a grasp on this program, it is next to impossible without a significant amount of training from PTC. This is probably part of their business plan because truthfully, their documentation and training programs are superior to the software itself. It seems like the designers of this software have had no personal experience using a system. The user interface is obviously a copy of what Autodesk has been doing - the Ribbon UI. However, they have failed at the ease and convenience that Inventor provides and it seems like their employees do not understand why they are programming their product in this way.
Right clicking for everything is a nuisance. The commands should be explicit. Once a command has been initialized, it should state what is needed to accomplish a successful feature. When I hover over some of the commands, it's as if the programmer just did not understand the point of what he/she was trying to create. For instance if you hover over swept blend, the information contained says "create a swept blend". Inventor shows a preview of what the function actually does in a quick movie if you hover over it, plus it provides a link to learn further information and even provides an exercise showing explicitly how to use the function and what must be defined for the function to work. PTC expects that you just know that you need to add certain references without actually telling you that you need it. For instance, the rotate feature needs a centerline (should be able to use any datum axis) which you then need to right click and define it as the rotational axis. If you try to do this through the message box, it will not work. There is no documentation in the help file saying this needs to be done. My anger continues to grow.
Also, patterning complex features is pretty much a null exercise, since it takes Creo 20 minutes to regenerate the model. I have never experienced this with Inventor. Their software updates automatically after a function is confirmed. There is no need to repaint/regenerate.
Assemblies:
The constraint system seems to have a mind of its own. After applying an angle constraint just this morning, and the preview showing the correct orientation, after confirming, the model just sort of reversed the direction and tilted on another axis which was untouched. I know it's difficult to picture this. But just picture me wishing that Creo was tangible and that I could soak it in Ethanol and watch it burn a slow painful death.
That's enough.
Please provide some insight as to why this program is any good at all. I need to like it. I want to like it. I have to like it. But right now, it is the bane of my existence. Some of the simplest commands that I try to initiate do not work as intended. There are way too many idiosycrasies that 'just have to be known' through experience. There is no way that someone could just hop on this program and start using it. However, with Inventor, they have actually put work and research into making their product user friendly. So much so that at my previous position, I could educate a technician in a day or two and they are off and running producing components, assemblies, and even drawings.
Please help me think of Creo as a helpful tool instead of a hinderence and outdated piece of garbage.
Thanks for your help.
~Bart
Personally - I love Creo ...Of all the softwares I had to suffer - it's the one that I can always find a solution to problems. The others would hit walls that just made it so it could not be done.
Back in '95 I had been chosen to test all the 3D CAD systems and did the 1 week training for each... Pro/E was the one I found intuitive and easy. Things were done in an order that made sense - to me. After one week intro, I was able to go into full on design, and product was being made.
In the early 2000's I was contract to companies that could not do what had to be done in their softwares - cause each has it's problems. I was able to do it in Pro. This cemented for me that PTC's product - though a challenge sometimes to use - was/is the better software.
I agree with you. I too have been using Pro/E since version 9.0. It is a tuff software, I guess over the years I learned to understand what the software was wanting from me. The basics I learned as a high school student in drafting class and geometry really have paid off. Maybe people need to go back to the basics. Users need to understand what info the software needs mathematically to work. CREO is not a software for the lazy user. On the other hand as an experienced user of CREO, I will admit that Solid Works and Inventor are quite easy to use.
Response 178 was meant for Daniel Goodman
I don't get where people think solid works is intuitive.  I am a creo user and I have set out to teach my self the software a couple of times.  I started by building a cube and adding Radii to it.  That's all it took before I decided that it sucked and I didn't have to go any further.
2cents to add. I've been using SW for the last 6 months making a variety of simple parts.  The software is relatively easy to pick up but it's not completely intuitive.  Some features are great, but overall I agree with what others have said: Combine the best of Creo and SW and you'd have a good package.  I also agree with the above where it's the CAD operator who can make a big difference.  That being said in the company I'm in now there's a very regular if not daily refrain about the problems of being able to manage an assembly of any complexity, SW just doesn't have the ability to do it dependably.  This is where Creo shines, large assemblies even in fully regenerated mode work great, and huge assemblies can be done with the other tools provided.  SW can't compete when it comes to large assemblies.
Best Regards.
I worked with Inventor for about 8 years, and now I am working with Creo 3 (since Creo2) and I can say some things:
Creo is a good piece of software. I can give it that. But there is some things that is too dumb.
Like tables in the drawing. WHY there is no snap on it? The repeat region function.. my god.. its a nightmare! I can not insert a centerline where I want to, only the ones in the model.
In the assembly, WHY normal is the default constraint? I don't recall EVER used it! To move part, WHY do I have to hold button to drag it?
In the modeling, if I start a feature, like extrude, and when I finish the sketch I figured I missclicked and what I wanted was a revolve. All that sketch work was for nothing.
And the helical sweep function? my goodness.. I can't even think in a more complicated tool (possibly there is one..).
There is some things.. a few.. that I can praise, but not near enough to even consider it a good software.
It does the work, no doubt, but it could be done a LOT easier.
But yeah.. just putting out my frustration.
I totally agree with what you thought, too bad I will need to start the Creo soon 😞
Pro/E... CREO... the Epitome of Kludge!
