Print Screen Button not Recognized when Creo is the Active Application for Techsmith SnagIt?
We are experiencing a new issue where the Print Screen button used to trigger Techsmith SnagIt does not work when Creo is the active application. It used to work flawlessly, but recently stopped working.
- Its not a change in Creo because we have not updated Creo in 6 months
- Its not a change in SnagIt because we have not updated SnagIt in months (IT controlled)
My best guess is a change introduced by Windows Updates, Optional Windows Updates or Manufacturer Updates in Windows 10.
We use two primary suppliers for laptops and the problem appears to be isolated to Lenovo P series laptops running Windows 10. Lenovo has its own driver update tool keeping the laptop hardware and graphics drivers up-to-date which could add to the confusion.
Our current work-around is to click on another application to trigger SnagIt, but this drops any active UI in Creo. Simple screen shots are easy, but training screen shots are now a bit harder since the active UI elements are closed when another application is selected to use the Print Screen button to trigger SnagIt.
