My first guess is that it is a graphics card issue.
Add line to your config file "graphics win32_gdi" to see if this solves the issue. This option will make the program slow and is only for diagnostic purposes. If this fixes the issue, remove the line and try installing different versions the graphics card driver. The latest version is not always the best version.
Thank you. I will check it. I appreciate your advice.
Hello @YK_10644890,
It looks like you have a response from our community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
