2D Drawing Axis crosshair orientation.
  • January 3, 2025
  • 3501 views
I have a circular part  with a rectangular keyway in the front plane.
I have created an axis in the part normal to the front plane and referencing the right and top planes with 0.0 offsets. This is prior to creating any geometry.
In the drawing of the part the axis crosshair is shown in the vertical plane and horizontal plane parallel to the keyway when the view is shown as front.
If I rotate the front view by axis angle 45°, the axis crosshair are no longer shown as referencing the right and top of the part and parallel / perpendicular to the slot.
Is there a way to have the axis cross hair fixed to the datums in the part, so that when the part is installed in an assembly , the angular dimensions can be called out  depending on the position of the keyway. And if the part is rotated in the drawing the axis stay aligned to the keyway.
Any help on this would be greatly appreciated.
Best answer by Paul6
Hi All,
Thanks for your suggestions on how to show a cross hair in a drawing of the axis in a model.
I understand now that what I was hoping to display in a drawing or model, is not the default for creo.
It appears that I would require additional feature / axis etc in the model, to achieve the desired ability to measure the clocking angle.
kdirth
Select axis, RMB, Edit Attachment
Menu will pop up to select desired attachment.
Paul612-AmethystAuthor
The axis attachment is already aligned to the top and right datum planes in the part..
What are you suggesting should be selected as references?
This is the view I am wanting when the part is rotated.
In the drawing I can manually rotate the axis, but that requires knowing the angle the part is rotated.
As the drawing will have multiple views of the parts movement, with variable angles this would not be a suitable solution.
In the drawing (not model):
What you have:
To get the aligned, select the axis, right mouse, edit attachment:
Then select Parallel and select the line you want it to be parallel with (there are other options here, explore them too for future reference.
