(6.0/7.0)import dxf/dwg, no entity shows when selecting on the sub window
daiyuyang
Hi there,
I'm Steven. this is the very first post on the communuty.
My creo version is 7.0.
I tried to import the dxf/dwg file when i sketch.
A window will show up to warn there is too much entity in the file you are going to import.
It ask you whether to select certain entities to import but not all of them.
Then, a sub window will pop out, and there is no entity showing on that window.
You can see them only by choosing them.
I tried this on 4.0, and it works perfectly.
I encounter this only on 6.0/7.0
Do you guys come to this before?
Thank you.
tag or keyword for others can reach this issue"
you are attempting to import too many entities into Sketcher
subwindow
select entities you wish to be imported
bmi
(To:MartinHanak)
Resolved in  case C15782967.
Hi Steven,
Please refer to the article, so you can update Creo to new date code.
CS322506 Unable to display the entities in the subwindow after click on Select in Import Waring dialog when trying to import a dwg file which contains too many entities into Sketch mode of a part in Creo Parametric 6.0
https://www.ptc.com/support/article?n=CS322506
Solution:
  • Reported to R&D as SPR 9903895
  • Corrected in
    • Creo Parametric 6.0.5.0
    • Creo Parametric 7.0.1.0
    • Creo Parametric 8.0.0.0
@daiyuyang wrote:
Hi there,
Thank you.
subwindow
please report the problem to PTC Support.
Martin Hanák
bmi
(To:MartinHanak)
Hi Steven,
Solution:
  • Corrected in
