(6.0/7.0)import dxf/dwg, no entity shows when selecting on the sub window
Hi there,
I'm Steven. this is the very first post on the communuty.
My creo version is 7.0.
I tried to import the dxf/dwg file when i sketch.
A window will show up to warn there is too much entity in the file you are going to import.
It ask you whether to select certain entities to import but not all of them.
Then, a sub window will pop out, and there is no entity showing on that window.
You can see them only by choosing them.
I tried this on 4.0, and it works perfectly.
I encounter this only on 6.0/7.0
Do you guys come to this before?
Thank you.
tag or keyword for others can reach this issue"
you are attempting to import too many entities into Sketcher
subwindow
select entities you wish to be imported
