3-Newcomer
May 17, 2023
ASME 2018 symbols
  • May 17, 2023
  • 5033 views
Where can I find the symbols to be applied to drawing in accordance with ASME Y14.5-2018 standards?
I'm missing "Continuous Feature" symbol to meet the new drafting standard.
I am using Creo Parametric 7.0.11.0.
Hi @QNTran682 ,
All the symbols are there, all you need to do is to update the following model detail option (or drawing detail option, depending on which environment you are in):
Detail option name: symbol_font
Value: asme or stroked_asme
(you can access the detail options page via File-->Prepare-->Model Properties-->Detail options)
Once you will apply the new value for this option, you will see much more text symbols available:
QNTran6823-NewcomerAuthor
3-Newcomer
May 17, 2023
Thank you!
I found the symbols to insert. However my text box does not display the Symbol graphic text properly. So I can't see what the symbol is before inserting. How can I make it look like the way your pictorial looks? Here's what mine looks like.
@QNTran682 wrote:
Thank you!
please do simple test:
  • create new empty drawing
  • set symbol_font asme
  • add new note
  • display Library symbols dialog box
