8-Gravel
June 6, 2024
All Creo parts are in directory but won't open assembly correctly, says missing parts
  • June 6, 2024
  • 3 replies
  • 2917 views
All Creo parts for an assembly are in the directory but won't open assembly correctly, says missing parts. When opening in Creo View all parts show up. Trying to create a STEP for file for our vendors. Any ideas here?
Are the "missing parts" a newer Creo version? Have you tried opening them individually?
jeuclide8-GravelAuthor
8-Gravel
June 6, 2024
Yes they open individually.
8-Gravel
June 6, 2024
Yes on both accounts....
When you try to open the assembly, creo (not creo view) will tell you what parts are missing. I would start with the first one and verfiy you have that file. After a verifications, if the files are in the folder as expected, then you may have other issues.
If there are still files missing,, How did you obtain the creo files? How did they get to the folder you are opening them from?
8-Gravel
June 6, 2024
Yes say they are missing, they do exist in the directory and can open them by themselves. Suspected something bad from customer, customer supplied files. In folder from someone adding them from customer.
How are you trying to open the files? Drag and drop?
I would suggest you first set the working directory to the folder where all the files are (one big folder, no subfolders)
Then use file open.
please show us the list of files in File Explorer and also Creo Model Tree.
