Hi everyone,
Can anyone please let me know, if there is any option to auto update in created hole table, if i updating th hole parameters (like dia, positions).
Santhosh,
I do not know if there is an option for auto updating hole tables, but be very careful using Hole Tables. You definitely want to double check the results against the model. I have had issues with holes not appearing in the table when they should.
