Assembly Relations for Family Table Parts - Session ID Changes when Part is Replaced
For an example, I have a family table of angle parts. The cross section (size) of the angle can change based on the value of a parameter that defines the cross section. The length can also change which is driven by relations in the assembly.
If I have an assembly with 3 total angles in it, (1) of angle 1 and (2) of angle 2. The relations in the assembly might look like this:
for angle 1: length:2=d2*3
for angle 2: length:4=d10
The problem is, if I replace one of the angle 2 parts with an angle 3 part, the length:4=d10 relation changes to length:6=d10. Because there is still one of the angle 2 part in the assembly, I don't want the session id to change in the relation. I want the length:4=d10 to stay length:4=d10 and not change to length:6=d10
Does anybody have a solution so the session id doesn't change when replacing parts if the original part still exists in the assembly.
Thanks for any help.
Steve
