8-Gravel
September 29, 2022
Assembly drawing
  • September 29, 2022
  • 971 views
Hi, I have a question that may be very simple.
When creating an assembly, I use both parts and assemblies in it.
When I am making the parts table, it will show me the parts and the whole assembly. How to change so that the assembly used is also broken down into its parts and are in the table
Best answer by tbraxton
You need to make your table recursive.
In the table tab:
repeat region-> attributes-> pick your tables->select recursive->done.
tbraxton
tbraxton22-Sapphire IIAnswer
In the table tab:
