Assembly model scale
  • May 4, 2016
  • 2 replies
  • 10719 views
I would like to change the model scale of a whole assembly (Creo2)
Model \ Operations \ scale Model
> entering a scale value (1.5)
> confirmation (Yes)
This don't have any effect. So we have to change scale part after part.
Then, if this operation is not possible on an assembly, strange to see this option is available in assembly mode.
Is there any manner to do this ?
Best answer by StephenW
Don't use that scale. It will only work part by part.
You may be able to use a UNITS change to accomplish this.
Go to file, prepare, model properties and adjust the units, if you can set the units change to accommodate your needed scale.
First unit change would be to "interpret" the dimensions (1" becomes 1.5 units).
Second unit change would be back to the "convert" back to the desired units (1.5 units becomes 1.5")
I just don't know if you can make it work for any scale factor or if it has to be only a real units change, which wouldn't work for you.
I know it's not a good explanation but you might want to experiment with it to see if you can get something to work.
kdirth
The option in the assembly would control dimensions created at the assembly level such as offset datums, assembly constraints, and assembly cuts.
StephenW23-Emerald IIIAnswer
Using Creo 3, I'm not getting the option to go 1:1 with submodels checked. Since I'm working with an assembly of several hundred parts I'd rather not scale them individually! Any new information to share with the masses?
Are any of your parts locked (PDMLink) or otherwise not modifiable?
The include sub-models would need to be able to modify each and every part in the assembly.
If there are any parts locked (using pdmlink or otherwise), you can't scale using the "include sub-models"
