Auto-scale first sketch: has anyone managed to make it work?
  • September 12, 2022
  • 2 replies
  • 2468 views
in the introductory video of what's new in Creo 9.0, in the Sketcher section, there is "Auto-scale first sketch".
Looking in the config I found the option:
sketcher_auto_scale_dimensions which by default is set to "yes".
The description of the option is: "When creating the first sketch in the model and modifying the value of a weak dimension for the first time, controls whether to auto scale the sketch in proportion to the modified dimension. "
I haven't been able to make it work yet, maybe I misinterpret it, has anyone managed to make it work?
Thank you.
I use creo 9.0.0.0
Best answer by TomU
It seems like it may be necessary to recreate your start parts.  I can get the new behavior to work if I start from an 'empty' part or the PTC provided start parts, but not if starting from one of our existing start parts (templates) and the initial sketch contains more than one dimension.
TomU23-Emerald IVAnswer
bmancini15-MoonstoneAuthor
Thanks TomU,
following your instructions I was able to make it work!
Hi.
I also came across this problem. The cause of this problem are sections defined on star part.
If there are no sections, then autoscale works ok.
If there are sections, then autoscale is not working.
I think this is a bug in Creo 9.0. I have opened a case with PTC support.
Domen
kdirth
I expect that the sections in the start part have effectively set the scale of the part.
