BOM Table Index - with level
  • August 15, 2025
  • 2 replies
  • 419 views
Is there anyway to include level in the index for a multi-layer BOM. For example, I like to have index "1" for first level of assembly and "1.1" as the 2nd level, "1.1.1" for 3rd level and so on and so forth? This is the format of the ERP system required to import the data into it.
I am using Creo 9. In the table repeat region can only have "rpt.idex" or "rpt.level".. But "rpt.level" on show 1,2.3.. for the level.
I am not sure whether current Creo functionality enables user to create requested BOM.
I can imagine that the following procedure could work:
  • create BOM in Creo using repeat region
  • export table contents into csv file
  • open csv file in Excel and create the required index
  • save Excel file into csv file no.2
  • import csv file no.2 into Creo drawing
Unfortunately the above mentioned solution is not ideal. The imported table contains "dead" data.
Community Moderator
September 30, 2025
Hi @SC_TK,
Anurag
