When I'm writing balloon note with a multi-lines it makes them as a separate balloons aligned Horizontally.
Is there any method to make them aligned Vertically like this in one note like the previous one
use Vertical option. In my test values were displayed from bottom to top, so you'll probably have to enter the values in reverse order.
Hello Martin,
It works great.
Can I have both as a table distribution like this
(In a single note)
@ELDAFRAWY wrote:
Hello Martin,
It works great.
(In a single note)
I do not think that both direction "table" can be created using Balloon Note command. I am sorry I cannot offer any other solution.
