Basic question about "Missing Reference" error
Hi all,
I am very new to PTC Creo Parametric 3.0, and I am trying to replace a .prt file in my assembly with a 3D part model that I downloaded from the web. For example, the part that I am replacing is a resistor on a Printed Circuit Board. Currently, the resistor is just a 3D rectangular box, but I downloaded the actual 3D model of the resistor and replaced the part. I renamed it the same as the original part, as well.
Since I am very new to Creo, I know that this is probably an easy problem to solve. I am guessing that the 3D part that I downloaded doesn't have the same reference that the original part had. But I am not very sure how to fix this.
Thanks in advance for your help!
