Blue object lines in Assembly
  • February 24, 2026
  • 2 replies
  • 88 views
I have a small class project.  A number of students have bright blue lines shown on parts, but I do not.  We're all in Creo +.  The lines don't appear in the part view, just the assembly.  They aren't visible sketches, and I've tried hiding all the different layers and I can't make them go away.
What am I missing?
kdirth
Looks like copied edges.  Can you show the model tree so that we can see what types of objects there are.
I would ask for the model, but you are most likely using a student version which most of us can not open.
kleipold10-MarbleAuthor
Nothing really odd about it - but when I opened it today - everything looked normal. I'm not sure what changed.  I'll ask the class if they are still seeing similar issues.
They could be from the internal sketches used in the part features. There may be a config option that isn't set to hide internal sketches. You could create a layer and add them to it.
