Bulk modify for parallel lines (or similar parameters)
- February 21, 2021
- 4 replies
- 4969 views
Is there a way to bulk modify certain parameters when sketching?
For example, I have four parallel lines, and I want all of them to be 20 mm apart (equidistant).
I was hoping to be able to select/highlight all four lines (or the dimensions), then click on the NORMAL button and change all four dimensions in one stroke (please see picture attached)...
Unfortunatelly, it does not work like that -- for four lines it is not a big deal, but if you have hundreds of these lines to align like this, such a shortcut would be a tremendous productivity trick!
P.S. I chose the label forced by the system, could not find a SKETCHING label so I took the one that sounded close...
