CHANGE LINE STYLE ON DIFFERENT SHEETS
I would like to change styles of the same sketched line used on two different views and on two different sheets.
In the first view, and in the first sheet, I want to use a yellow "geometry" style line.
In the second view, on second sheet, I would like to use a yellow "phantom" style line.
I've tried to use the "Layout --> Line Style" command: when I change the style of a line on one sheet, it change the style on the other sheet too.
Is there a method to obtain this result?
Thanks a lot.
