CREO 10.0.0 - Standard Tapped hole, Thru Thread depth setting missing?
Just started using CREO Parametric 10.0.0..... and notice that there is no option to set a standard tapped hole to have a thread depth through the entire length of the hole. For example, in part modeling making a hole-set references - set Standard type - set to thru-all depth setting- add tapping - go to Shape tab - the only option for thread depth is a blind specified value. No Thru Thread option.
