CREO 5; Piping; where is the length of a pipe stored?
  • September 28, 2020
  • 4561 views
Hello, can someone tell me what the parameter is called where the length of a pipe is stored?  I'd like to reference this in a drawing table so there is a link between the drawing and the pipe?  Thanks.
For a non-solidified pipe, you can select "Piping Info" and change the Definition dropdown to Segment. From there, by selecting Info at the bottom you can see the length.
For solid pipes segments, the two parameter names are "LENGTH_CENTER" and "LENGTH_PRE_CUT" that you call out in 2D drawings.
Cheers,
wbottis14-AlexandriteAuthor
What is the difference between "non-solidified" and "solidified" pipes?  I am trying to apply this to a flexible pipe.  Upon creating a note in the associated drawing and entering '&LENGTH_CENTER', the pipe length does not appear.
Before they are solidified, pipes in Creo are just features, not solid geometry. By solidifying pipes, you create solid geometry that has mass and other properties than can be called out downstream. See document (here) on how to solidify a pipe/hose.
