CREO PARAMETRIC: How to delete an assembly from an assembly
  • March 19, 2024
  • 2295 views
Hi everybody
Do you know how I can delete an assembly in an assembly?
Br,
Hasan
Best answer by StephenW
I'm still confused.
Do you want to delete the group AND all the components (or features or whatever)?
Then just use RMB delete and hit OKAY.
If the components or features within the group have other references, you will get a different message asking how you want to handle the references.
The way your question is phrased, Just select the assembly and push delete.
I'm guessing there is more to it than specifically how you asked the question?
I am trying to delete this ammaebly, but it does not work.
You want to delete the group? And all the components in the group?
Or  you just want to remove the group?
Use "ungroup"
