Hai everybody,
Currently i am create general view for parts in A4 layout, after inserting some parts general views, space not enough for inserting some parts in it, i am desired to change layout from A4 to A3 is it possible to change it. if yes how to do?
in Creo 2.0:
doubleclick A4 at the bottom of graphic window.
select field containing size, open the list and select requested size
Martin Hanak
On the sheet tab (sheet 1), right click and choose setup (or go to the layout tab and select sheet setup). You can change your sheet size there.
in Creo 2.0:
Martin Hanak
