Can't Name a Dimension "G"
  • October 28, 2010
  • 3 replies
  • 1832 views
Folks,
My colleague is renaming some of his dimensions so he can call them out in a table on the drawing. He has dimensions labeled "A", "B", "C", "D", "E", and "F", but when he tries to name a dimension "G" it tells him that "this name is reserved or exists already."
Is "G" just not an allowable name for a dimension? We're on WF5.
Tim
Tim Giauque
Project Engineer II
FN Manufacturing, LLC
Phone (803) 736-0522 x383
Fax (803) 865-3543
tgiauque1-VisitorAuthor
Well, that was quick. "G" is reserved for gravity in relations.
Thanks to all who answered so quickly.
It is likely that there is already a parameter named "G". Perhaps from a
previous attempt at naming the dimension "G" and then deleting the
dimension. The parameter will still exist. If that is the case, Delete
the parameter (careful that it is not being used somewhere) and rename
your dimension to "G".
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
cell: (216) 990-8711
fax: (440) 266-2311
www.parker.com
Tim Giauque <->
10/28/2010 01:23 PM
Please respond to
Tim Giauque <->
To
'Pro/E Mailing List' <->
cc
Subject
[proecad] - Can't Name a Dimension "G"
Folks,
a table on the drawing. He has dimensions labeled ?A?, ?B?, ?C?, ?D?,
?E?, and ?F?, but when he tries to name a dimension ?G? it tells him that
?this name is reserved or exists already.?
Is ?G? just not an allowable name for a dimension? We?re on WF5.
Tim
Tim Giauque
Project Engineer II
Fax (803) 865-3543
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailing list Manage your subscription
Use of this email content is governed by the terms of service at:
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
Tim,
G is a reserved, internal symbol for the acceleration due to gravity. You could use something like G_DIM instead. Best of luck!
Thanks.
Frank H. Strieffler,
Director of Technical Committees, for PTC/USER
Project Specialist Staff, for Lockheed Martin
Mechanical Hardware & Test
Lockheed Martin Engineering
Cherry Hill, NJ
