Can't add reference dimension to sketch
  • April 26, 2024
  • 2646 views
I would like to be able to find out the reference dimension from the blue lines to my orange sketch, but the "Reference" button is greyed out. Help me please.
I'm using Creo 2.0
On a nearby computer, my colleague is able to add this reference measurement. I tried to import its configuration settings - it didn't help. Just in case, I will attach a file with my configuration settings.
tbraxton
If you suspect it is related to your config then launch Creo using your colleague's config settings and test it on your machine. Without the model it is unlikely someone can troubleshoot this.
I did exactly what you suggested. Another settings file did not fix the situation. This happens to me in all my models. My colleague does not have this in the same models. But I don't mind attaching the model file 🙂
tbraxton
You labeled the OP with 2D drawing. Are you in drawing mode or part mode when experiencing this issue?
