Can't remove an image from a model
I added a few images to my model using View > Model Display > Images > Add
Now I want to remove those images. I tried following PTC's instructions (link below), but I'm stuck at step 2; I can't select an image. Clicking the image in the graphics window does nothing, and when I click the imported images dropdown, it's empty.
Is there any way to get rid of the images from the model? I've tried moving / deleting the source image, but this just shows a gray area where the image used to be and gives a "could not locate image" error.
I'm using Parametric 2.0.
