Cannot auto-route cable in Creo Cabling
- January 22, 2019
- 1 reply
- 3862 views
I am trying out a simple test part to show that I can auto-route a cable between two connectors by importing an .nwf file. I am able to auto-designate the connectors, but I cannot seem to get the entry port to work correctly. I have indicated in the .nwf file that each pin should go to the "ENTRY" coordinate system, but when I create this coordinate system in the connector model, the auto-designator tool does not seem to locate it. When I try to auto-route cable C1, the connectors do not auto-populate.
Any assistance would be appreciated! The .nwf file is attached as a txt file.
