Chain Connection
This idea is about a mechanism connection. I cannot imagine how many machines uses this type of connections (bikes, motorcycles, cars, etc...).
Now, is it possible to add the Chain Connection Type to the Mechanism Extension?
Advantages of this:
- You can control parameters related to this type of connection. For example, you can control if the tension of the chain is the desire.
- You can control how many pins you want in the chain, in that way you can add or remove pins according to chain standards (bike chains for example).
- You can create and assembly of a chain and a gear without 1000 connection types (3D Contact, Cam Follower, etc...)
- You can create this type of connection in a more easy way and in less time than the normal way (that by the way, I don't know how to do it).
