8-Gravel
October 26, 2022
Change a dimension color on print
  • October 26, 2022
  • 936 views
Hello, I have questions. Can I change the color of one dimension in a drawing on a plot? I am modifying the part and I would like to show the changed dimension, e.g. in red. I use a Cre parametric 2.0
_________________________________________________________
Translated From Polish by Iuliana Lazar with Google Translate on 26 oct. 2022
Witam mam pytania. Czy można zmienić kolor na jednym wymiarze na rysunku na wydruku? Dokonuję modyfikacji części i chciałbym pokazać zmieniony wymiar np. w czerwonym. I use a Cre parametric 2.0
Best answer by mkajdan
Select the dimension you want to change the color of, Format Tab then the color key in the upper right corner.
mkajdan14-AlexandriteAnswer
