Change default family name Instances or fastest way
  • June 5, 2023
  • 2 replies
  • 1048 views
Is there any way to change the default family naming instances?
like I need 001,002,003,004 etc for new instances.
I tried with open with excel replace all.
But the moment I save this tmp excel file the family table disappears.
Also tried with Mapkeys to carefully delete INST1 and write 001 that also not working. I have 100+ parts require family table instances. Any common idea to rename the instances?
Best answer by MartinHanak
in Excel you have to select the right range ... see red rectangle in following picture
Oops., The problem is there is one more INST in the header which is also replaced as 00. Leaving that will not destroy the family table. Thanks.
You can only change the names on newly created instances if using Windchill. Once they have been saved, you have to rename them in Windchill and then update the parameters by verifying the family table again.
