Changing default tolerance from "ansi" to "DIN/ISO"
i am using Creo Parametric 6.0 and changed some settings in the configuration editor.
But at one point i am struggeling to change it to default. I wanted to change the geometry tolerance from "ansi" to DIN in the config file.
After that i saved it added it back and restarted but it is still on "ansi" when i open the part preparations where i can select materials etc.
But on the configurations it says it is DIN. Does anyone know why and how to solve this?
