Checking Part Association?
New user here. I am currently running Pro/Engineer Wildfire 4.0 and I was wondering if there was a way to check all the associated fiels a solid aprt was attached to.
For example if I used a specific part in mutiple assemblies and wanted to deleted this part completely, is there a way to see which assembly files the part is attached to before I delete it?
Thank you for your help.
