Checking in from embedded browser with "Models and Viewables"
  • August 17, 2021
  • 2753 views
I have a very large assembly that takes long time when I am trying to check in. When I do check in from embedded browser the drawing preview will be not be available. Therefore PDF does not published whenever a change task is completed. Is there any way to check in from embedded browser with "Models and Viewable"?
Do you have a secondary publishing process set up from Windchill using CreoView Adapters?
This will publish all files that get checked in background.
Using Models and Viewables when you do a custom Check-In utilizes your active Creo session to do the publishing. If you have the CreoView Adapters set up, just do an Auto Check-In (as long as it is not the initial check-in and the file is in the proper location) and let the publishing take place in background.
HTAVAN1-VisitorAuthor
Thank you for your reply BenLoosli. I am trying to use "Models and Viewables" in Windchill embedded browser not from Creo. Please see snap shot attached.
Thank you very much for your help @BenLoosli . I will ask admin to do that. 👍
