Clip leader line in drawing
When I have two linear dimensions that are attached to successive elements, I can "chain" them as depicted in the first figure below (left), by aligning them and using a dot where two consecutive arrow heads should be (below the middle line). I can also do the same when chaining an angular and a linear dimension (see again first figure, on the right) by the same method; this, however, leaves a short part of the linear dimension that goes beyond the witness line (see second figure below).
Is there any way I can clip leader lines, when the arrows are outside the witness lines? Note: I know how to clip the witness lines themselves, but this does not apply to the leader lines.
Any help much appreciated.
Best regards
Oblomov
Left: two linear dimensions in chain. Right: an angular and a linear dimension
