3-Newcomer
January 10, 2022
Collapse feature
  • January 10, 2022
  • 2083 views
Hello to everybody.
Is there some way to use collapse feature in sheet metal module?
if not, how is possible to do something similar?
Thanks!!
@AlexITG wrote:
Hello to everybody.
Thanks!!
  • open sheetmetal part
  • activate Sheetmetal tab
  • expand Operations list
  • use Convert to Solid Part command
AlexITG3-NewcomerAuthor
3-Newcomer
January 10, 2022
Thanks for the answer!
In this way I would lose all the features. I would like to collapse just some features (for example some shrinkwrap), not everything...
Hello @AlexITG
The technique proposed by @MartinHanak (Thanks a lot for that!!) is the only one allowing to produce an Independent Geometry Feature (affecting therefore the whole history of the sheetmetal model). In Sheetmetal environment (among several others, all described in our article 59684), the Collapse capability is not available as currently not supported.
Serge
