Constraints using Inventor models - axises not visible
- July 2, 2017
- 2 replies
- 8978 views
Hello everyone,
I am trying to investigate mechanism simulation in PTC Creo 4.0 using models imported from Autodesk Inventor 2017.
In the other topic I started (which unexpectedly dissapeared) I got information I should use mechanism constraints in the Creo to run mechanisms. I tried to do that, but I encoutered number of issues, if someone helps here, that would be highly appreciated:
Do I have to assembly whole model, part by part using PTC Creo constraints to study mechanisms? Is it possible to set only those constraints being meaningful for mechanism movement and left all the others as it was all set in the Inventor? I tried to do that but I found it impossible to change Inventor constraints to eg. Pin conection. I can't choose Pin conection (see attached)
At the same time when I tried to import Inventor parts one by one and tried to assembly them step by step I also was not able to do that. When I wanted to use Pin constraint that was possible, but I could not see the axises. Using parts created in Creo everything was all right. (see attached)
Thank you for all the support,
Oskar Kos
