Convert from .prt to .step using mapkey
Hello everyone,
I am trying to convert the .prt into .step, during this process we can the co-ordinate system as well. I have the common name for co-ordiante system all parts. I have recorded the mapkey with selecting the co-ordinate system. If i am running the same mapkey for different parts, it is unable to select the co-orinate system. Gving the error message "Select co-ordinate system, Export aborted". I have this doubt and also, How to select the particualr feature from tree using the name..
Thanks in Advance
