Converting Assembly to Part
Version Creo 9
Good Morning. I received this as a step file which opens as a assembly. I am making one of the horizontal pieces about 17" longer. Because it is an assembly with no constraints already built in, I have to move and constrain all pieces next to the 17" lengthened pipe. Is there a way to just save this as a multibody part and make the change so that everything moves together?
I have tried file and save as to see if I could just output it as a part but that doesn't seem like an option. I am used to Solidworks where everything is easier. Thanks in advance
