Converting NX into Creo and extracting to .prt file
Right now we have a customer who is giving an NX file project, so we imported the model into creo and it was opened as an assembly and then I used IDD to clean it up. Now I need to extract one specific part as a (.prt file) since we will put it in CREO tool deisgn extension (which requires .prt file). I have tried (1) Copy/publish geometry however the part does not appear when I open it. I have tried (Shrinkwrap). however this option leaves holes in the surfaces. Any help will be appreciated.
Thank you.
