Is there a way to copy sheets from one drawing to another drawing?
(It's really deleted sheets from an old revision into a newer revision of the same file, but if we need to do it outside of a workspace we've no problem with that.)
On your drawing, in they layout tab, insert drop down arrow, import drawing/data.
