Create a point where two objects contact using pairs clearance?
I am using Creo 8
I am trying to determine the point where two objects contact each other. You can measure the value with pairs clearance, and it provides a point of contact, but you cannot do anything with that point. I would like to be able to take the point that it determines, and create a plane to measure the diameter where the objects are touching
