Creating 2d drawings from 3D models in creo parametric
  • March 13, 2012
  • 53699 views
I created some models in creo elements direct express which I saved as stl files and would like to convert them to 2D drawings in Creo Parametric. Is this possible, and if so how?
Best answer by KevinBradberry
To learn drawings, check these out:
http://www.ptc.com/products/proe/tryout/tutorial4/printable_page.htm
http://mrbrunelle.org/proE/tutorials/06_DRAWINGS.pdf
As for STLs in drawings, I'm not sure now. With Wildfire 3.0 I remember being able to select edges and faces of STL models for placing dimensions, but now with Creo/5.0 I can't do it. Hopefully someone else will chime in.
Thank You, Where can I find "Get Data, Import"?
