Creo 11 sketcher - box around dimensions
six10
Hello, we migrated from Creo 8 to 11. I have a problem in sketcher, those blue boxes around dimensions. Upon entering a value I cant even see the number. Any Ideas what could be the problem? I dont know if its graphical glitch or some setup/option problem.
MartinHanak
(To:six10)
please read https://support.ptc.com/help/creo/creo_pma/r11.0/usascii/index.html#page/model-based_definition/to_set_the_background_for_dimensions.html document.
You can also play around with the following config.pro options.
Martin Hanák
3 REPLIES 3
MartinHanak
(To:six10)
Martin Hanák
... additional suggestion:
Start Creo without using your specific config.pro files. This test will tell you whether the problem is caused by some config.pro option.
Martin Hanák
Thank you, that was it.
So to specify, under options/entity display, sketcher background color default is now blue. I changed it to white, and that was the solution.
